Andere Endschalldämpfer
Re: Andere Endschalldämpfer
Beitragvon bazi » 14.09.2009, 11:38
to be curious...
bazi
Beitragvon Remo » 14.09.2009, 20:48
Hallo zusammen
Hier das Zitat vom Schweizer Bodis- Importeur:
Also, da ist noch gar nix, die S1000RR ist halt noch zu neu, es wird winter
werden und bis was raus ist warscheinlich anfangs 2010
Ja dann warten wir mal ab was alles im November in Mailand gezeigt wird
Gruss
Remo
Motorrad: BMW S1000RR 2019
Beitragvon Nigel » 24.09.2009, 01:20
Look at this picture. It seems that this is a full pipe (no cat) with the short Akra can. I think this is what they will be selling as a full pipe option. Or it may even be that you have to cut off the cat and it is just a link pipe and can :?:
P.S. The pic is from Pfeifer's stunt bike at the Bol d'Or.
Nigel.
Nigel
Beitragvon dragomore » 24.09.2009, 11:44
Good catch ... the Akra really looks good! Slip-ons are usually street legal and there is no chance to comply with the emission standards without a pre-silencer. Thus I assume it is the full system! 8)
By the way, here is the (already shown) prototype of the Arrow full system on a stripped bike. It's also not too bad, however, I hope that they will change the mounting of the silencer. :twisted:
dragomore
Beitragvon Nigel » 24.09.2009, 15:00
Exactly my thought. Everythin on the Arrow looks fine except for the weld for the mounting bracket. I like the style as well. I hope it changes.
Nigel.
Nigel
Beitragvon Jokefrett » 05.11.2009, 13:43
hier mal ein paar Bilder vom Akra-Stummel
http://www.motoblog.it/galleria/big/ter ... -1000-rr/1
... immer 'foto successiva' drücken ...
Jokefrett
Beitragvon OSM62 » 21.12.2009, 15:39
Deivil aus Frankreuch hat jetzt auch nen ESD für die S 1000 RR im Programm:
Beitragvon Nigel » 21.12.2009, 16:33
See here. there is a long and short Akrapovic slip-on. You need to cut and paste the link as it has [ ] in it and it will not hyperlink properly.
http://shop.akrapovic.de/pdf/nav_453y_b ... rr_10_so_t[1].pdf
Nigel.
Nigel
Beitragvon Nigel » 21.12.2009, 16:39
This is what I bought. It is supposed to come with a carbon heatshield.
Nigel.
Nigel
Beitragvon Speedtrip » 21.12.2009, 16:51
Hmm also irgendwie sieht das Bike unharmonisch aus mit der Koplettanlage ... das erste Bike was mit Sammler besser aussieht. :shock:
Speedtrip
Beitragvon q-treiberr1200s » 21.12.2009, 16:59
Hallo Speettrip, die Harmonie stellt sich wieder ein, wenn man den großen Spoiler drauf macht. Wenn man 2 Riesen für die Komplettanlage hat, ist auch noch ein Spoiler drin.
Gruss aus Berg
Horst
q-treiberr1200s
Beitragvon Nigel » 21.12.2009, 17:21
The problem is that nobody makes a complete spoiler (belly pan) that you can use for the road. None of them have the solution for the side stand.
Nigel.
Nigel
Beitragvon Speedtrip » 21.12.2009, 18:00
q-treiberr1200s hat geschrieben:Hallo Speettrip, die Harmonie stellt sich wieder ein, wenn man den großen Spoiler drauf macht. Wenn man 2 Riesen für die Komplettanlage hat, ist auch noch ein Spoiler drin.
stimmt mit spoiler passt es wieder
Speedtrip
Beitragvon Flisi » 21.12.2009, 19:35
Nigel hat geschrieben:The problem is that nobody makes a complete spoiler (belly pan) that you can use for the road. None of them have the solution for the side stand.
Nigel.
Den könnte man ja einfach ausschneiden :wink:
Der Sinn einer Rennverkleidung ist ja das die Wanne geschlossen ist.
Flisi
