Fehlercodes...
Fehlercodes...
Beitragvon flor3366 » 20.08.2021, 15:49
ich bräuchte mal fachkundige Hilfe.
Ich habe diese beiden Fehlercodes ausgelesen:
3A1DA0
3A1DA2
Wäre toll wenn da jemand vielleicht auch nachschauen kann, oder sagen kann wo man Infos findet.
Ja, gegoogelt habe ich, gibts nix.
Danke
flor3366
Motorrad: S1000XR 2020
Re: Fehlercodes...
Beitragvon s1000rr69 » 20.08.2021, 19:20
Warum kannst du nicht googeln? :roll:
3A1DA0= detection of misfire also Fehlzündungen erkannt
s1000rr69
Motorrad: M1000R 2024
Re: Fehlercodes...
Beitragvon herbyei » 20.08.2021, 22:24
Code 3A1DA0
Label Zündaussetzererkennung
ECU Variant x_bmso1
ECU Label Motorsteuerung
Fault Code Description:
The Digital Motor Electronics detects several misfirings within a driving cycle.
The fault is detected when misfiring occurs in at least one cylinder.
Fault Code Conditions:
General Conditions Voltage supply between 9.0 V and 16.0 V.
Terminal Condition Terminal 15 on
Terminal Condition Terminal 30 on
Service Plan:
Rectify any fault that could cause misfiring.Check air intake duct.Check fuel system.Check ignition system.Check compression.Check crankcase ventilation.Check exhaust system for leak tightness.
Fault Impact:
The catalytic converter may be damaged or destroyed due to overheating.
Rough engine running
Service Notes:
The affected cylinders can be determined on the basis of the ambient conditions.
Code 3A1DA2
Label Zündaussetzererkennung, Zylinder 1
ECU Variant x_bmso1
DME monitors the duration of the power cycles and compares them with the other cylinders by evaluating the speed signals.
The fault is detected when the crankshaft during the working cycle of the respective cylinder is retarded compared to the other cylinders.
Service Plan:
Eliminate any possible faults that could cause misfires.Check air intake duct.Check fuel system.Check ignition system.Check compression.Check crankcase ventilation.Check exhaust system for leak tightness.
Fault Impact:
The engine operates in its emergency program.
Rough engine running.
Warnings:
Warning Lights Engine warning lamp off.
Re: Fehlercodes...
Beitragvon flor3366 » 22.08.2021, 10:06
s1000rr69 hat geschrieben:Warum kannst du nicht googeln? :roll:
Wer was gesagt dass ich nicht googeln kann?
Das von dir habe ich auch gefunden, aber das ist für mich keine qualifizierte Aussage.
Aber danke.
flor3366
Re: Fehlercodes...
Beitragvon flor3366 » 22.08.2021, 10:09
Hallo Herb,
das ist super, danke Dir.
Also aus dem Netz ist das mal nicht denke ich. ;-)
Danke Dir, meine persönliche Schrauberin wird damit was anfangen können denke ich.
Merci ThumbUP
flor3366
Mitglieder in diesem Forum: Google [Bot] und 7 Gäste
