diagnostic cable ???? + some questions
Re: diagnostic cable ???? + some questions
Beitragvon blue fan » 20.10.2016, 22:14
s1000rr69 hat geschrieben:
s1000rr69 hat geschrieben:Is there any one help me how can I fixed
Maybe,
there are only 4 pins in the BMW round connector
For the S1000RR 15 (the older one have a other plug connection)
10pin round connector --> OBD2
4 Ground --> 4+5
6 Kl 30 Power -->16
7 CanHigh -->6
9 CanLow -->14
In Ista-D you can search (right bottom), after your VIN input, for the wiring diagram. Search for X747*1S and all documents.
Before you must change to BMW Motocycle, on the top the wrench.
Have fun :D
:clap:
yes Exactly
I am looked at ISTA-D wiring diagram, The same as you wrote
My mistake is : Numbering Pins in Bikke ( 10 pin) Face-to-face lick mail pin
the correct numbering : back said - lick female pin
My Note :
Link OBD pins 1 & 16 to give ignition on signal to icom for this models. ( KL 15 : V - OK )
NOW I will correct PINS IN THE CHINES ICOM-D
after thin
re programming & change ml to km +Temperature Units F to C
i taeck a video and post it soon
thank you for all Forum members
best regard
ALI
blue fan
Motorrad: k 46 (12)
Beitragvon blue fan » 29.10.2016, 13:44
hi again
in this weekend , am try diagnosis K46 2015 with ISTA-D
Every thing is OK ( read & delete fault in control unit ) ISTA/D: Version : 3.51.25
work with icomA2 + ICOM-D adapter
I NEED TO be CODING a KOMBI but some Error plemplem
INPA Ediabas battery : on + ignition : on
in NcsExpert : v 4.0.1
there is ERROR
win i load profile then F1>>F3>> selected K24 >> ERROR CHASSIS .
am selecte and try all K1X , KH2 , M12 >> the seam Error
AND
in ISTA-P : V 3.56.4
in sitting>> Brand Selection bmw group & try to change bmw-UX for motorrad
KL 15 + KL 30 IS Good with battery charger
it's read only First line under programming > Vehicle details
vehicle no : Z00000 + E designation : k46 comes up but
Not Complete Checking vehicle access >>>>>>>
and
ERROR : (No communication with DME
The connected vehicle cannot be programmed and therefore cannot be processed with ISTA/P
Stare a session with ista if a diagnosis is wanted.
contact BMW Motorrad market support if necessary. )
i have TOOL32 + WinKFP +Dr GINI AND + older version NcsExpert 3.1.0 and old software DIS + SSS
any idea guy's
beast regard
blue fan
Motorrad: k 46 (12)
Beitragvon KaiO » 14.12.2016, 23:58
Never had any issues with ICOM A1 or A2 and original ICOM D cable.
Check your software setup.
BTW: Actual version is Ista D 4.03.13
KaiO
Motorrad: BMW S1000 RR 2015
Beitragvon blue fan » 11.01.2017, 21:48
KaiO hat geschrieben:Never had any issues with ICOM A1 or A2 and original ICOM D cable.
Yes KaiO
No Probleme connection with ISTA-D , READ & DELETE and Troubleshooting Fault its OK
but
i need some more info
why ISTA-P give Error
(No communcation whith DME, .... )
is there setup or Version OR ,,,,,
i want Coding KOMBI ( Ml>Km + F ْ > C ْ ) ANY Chan's with another Programs
Best Regard
ALI
blue fan
Motorrad: k 46 (12)
Beitragvon s1000rr69 » 12.01.2017, 00:57
blue fan hat geschrieben:i want Coding KOMBI ( Ml>Km + F ْ > C ْ ) ANY Chan's with another Programs
You can adjust the units direktly in the kombi. The name of the menu point is SETUP EQUIPMENT under the menu is the point SETUP EQIP:UNITS
It's described in the user manuel.
Have fun kiss
s1000rr69
Motorrad: M1000R 2024
Beitragvon blue fan » 19.01.2017, 07:44
Have fun kiss
Thanks for Reply, am try it this setup First under EQKIP: Units , Not Sure if can or not
and I'll trying today
this Week Am updating ISTA+ ; & ISTA P ; to Last Version 1/2017
I'll be back soon & respond what's news
Regard
ALI
blue fan
Motorrad: k 46 (12)
Beitragvon blue fan » 22.01.2017, 11:22
hi Every one
Mr. s1000rr69
winkG
there are some different in KOMBI Controller, am try one More About Your Post
in My K46 -2015 / Bike - USA , : Under EQUIPMENT Setup :
1. EQIP; CLOCK-TIME
2. EQIP; DIPS-BRIGT ,
3. EQIP; WARN-SPEED & LAMP ,
4. EQIP; BANK-DISP ,
5. EQIP; DTC-DISP
6. EQIP; BRAKE-DISP
ONLY
my Friend Also have K46 -2016 / Bike - Eur ; Under EQUIPMENT Setup Have it ( EQIP; UNIT; SPEED[KM/H] ; ODO[KM] & TEMP[DEG:C] ;CONS]L/100] ; CLOCK[12H] ;
So No Way to coding KOMBI
am finished Download this Version
ISTA-D 4.03.21.18572
ISTA-P 3.60.3.001
win i complete install ill Reply whats new
Beast Regard
ALI
,Qatif City
blue fan
Motorrad: k 46 (12)
