Help with victory mirrors- Lenkergewicht
Beitragvon damodici » 27.02.2015, 13:07
Hi Guys,
Im sorry to have to ask in English but i have some questions I think only the s1000r.de forum will know.
I would like to buy the Victory Mirrors and attach them to the bar end weight like the ones from Jorg66.
The problem is I don't think there are any left for sale from Jorg66 and need to find some alternative 'Lenkergewicht'? (i hope thats correct)
Do you guys know of another solution which mounts the mirrors nearest the grips and not on the outside edge of the bar end?
I would ideally like them in the same place like below:
I have found these on Polo Motorrad but only the Honda look to have the correct shape and they would need drilling to accept the M12 bolt for the S1000r
http://www.polo-motorrad.com/en/lenkere ... enker.html
do i have any other options and where can i buy some from?
thank you guys ThumbUP
damodici
Motorrad: s1000r
Re: Help with victory mirrors- Lenkergewicht
Beitragvon Supermic » 27.02.2015, 13:10
Hat denn da niemand der Beteiligten noch ein Paar gedrehte Lenkerendgewichte für unseren Damodici übrig aus einer der letzten Bestellaktionen!? scratch
Beitragvon Peti » 27.02.2015, 14:41
Wenn er es verstehen würde, würde ich sagen: Go to the turner and let you some maken. arbroller
Grüße, Peter
Peti
Motorrad: BMW
Beitragvon damodici » 27.02.2015, 17:30
Peti hat geschrieben:Wenn er es verstehen würde, würde ich sagen: Go to the turner and let you some maken. arbroller
I cant Peti as I dont have a detailed drawing but its a good idea. ThumbUP
damodici
Motorrad: s1000r
Beitragvon Supermic » 27.02.2015, 17:49
damodici hat geschrieben:
Scheinbar hat er's verstanden Peti!! arbroller clap
Beitragvon Peti » 27.02.2015, 19:02
Maybe you can take one original part to the technician. So he has a template and can change it only.
That's the way I did.
Grüße, Peter
Peti
Motorrad: BMW
Beitragvon damodici » 27.02.2015, 19:21
Its ok, Jorg66 might be able to help.
Fingers crossed ThumbUP
Es ist ok, könnte Jorg66 der Lage zu helfen.
Daumen drücken ThumbUP
damodici
Motorrad: s1000r
Beitragvon damodici » 27.02.2015, 19:22
Supermic hat geschrieben:
Die Macht der Google Translate arbroller
damodici
Motorrad: s1000r
Beitragvon Supermic » 27.02.2015, 19:39
ThumbUP arbroller
Beitragvon ExDuc » 27.02.2015, 21:10
Maybe a Washer with the correct diameter thickness 10 mill.
The original bolt is Long enough
ExDuc
Beitragvon damodici » 27.02.2015, 21:34
ExDuc hat geschrieben:Maybe a Washer with the correct diameter thickness 10 mill.
Yes that's a good idea, the original bar weight would need to be put in a lathe to create the smaller circumference and then a washer would do the job.
Hopefully though I won't need to as Jorg66 may be able to help.
I just wondered what other suppliers make something similar
I found this from Rizoma which I'm trying to understand how it works , I can't quite understand whether the thicker part sticks out from the bar and you clamp the mirror around that.
http://www.motorcycle-store.de/rizoma/B ... :2585.html
Or there are these which look ok in theory but won't be as heavy and also they're not threaded
http://www.desmoworld.com/shop/desmowor ... iegel.html
damodici
Motorrad: s1000r
Beitragvon lungco » 27.02.2015, 21:38
Hi damodici,
There is a much easier and pragmantic approach to fit Highsiders to the S1000R.
1. Get the Highsider EVO ones (new model)
2. Widen the existing hole to 12mm
3. Use both the ORIGINAL bar ends and bolts to fit
The result looks just stunning and rock-solid. IMHO ways better than using the old Highsiders and bespoke bar ends.
Cheers,
Lungco
http://img4.fotos-hochladen.net/uploads ... auw2ez.jpg
http://img4.fotos-hochladen.net/uploads ... rwva0b.jpg
http://img4.fotos-hochladen.net/uploads ... 8znvea.jpg
lungco
Beitragvon GiTo » 27.02.2015, 21:38
This could be another option for you. It adapts the thread-size from the rizoma bar Ends (metric M6) to the original BMW bar end thread size (metric M12)
Amat Victoria Curam. Bild
GiTo
Motorrad: S 1000 R 2014
Beitragvon ExDuc » 27.02.2015, 21:41
This is just to use the original rizoma bolt with the m12 tap of the bmw.
Doesnt help you.
If you want to, i send you a drawing of my bar ends (wich of course are the much better ones).
ExDuc
Beitragvon damodici » 27.02.2015, 22:02
lungco hat geschrieben:Hi damodici,
Cheers,
Lungco
What these ones?
http://www.polo-motorrad.com/en/victory ... hwarz.html
damodici
Motorrad: s1000r
Mitglieder in diesem Forum: 0 Mitglieder und 47 Gäste
