von herbyei » 20.08.2021, 22:24
Code 3A1DA0
Label Zündaussetzererkennung
ECU Variant x_bmso1
ECU Label Motorsteuerung
Fault Code Description:
The Digital Motor Electronics detects several misfirings within a driving cycle.
The fault is detected when misfiring occurs in at least one cylinder.
Fault Code Conditions:
General Conditions Voltage supply between 9.0 V and 16.0 V.
Terminal Condition Terminal 15 on
Terminal Condition Terminal 30 on
Service Plan:
Rectify any fault that could cause misfiring.Check air intake duct.Check fuel system.Check ignition system.Check compression.Check crankcase ventilation.Check exhaust system for leak tightness.
Fault Impact:
The catalytic converter may be damaged or destroyed due to overheating.
Rough engine running
Service Notes:
The affected cylinders can be determined on the basis of the ambient conditions.
Code 3A1DA2
Label Zündaussetzererkennung, Zylinder 1
ECU Variant x_bmso1
DME monitors the duration of the power cycles and compares them with the other cylinders by evaluating the speed signals.
The fault is detected when the crankshaft during the working cycle of the respective cylinder is retarded compared to the other cylinders.
Service Plan:
Eliminate any possible faults that could cause misfires.Check air intake duct.Check fuel system.Check ignition system.Check compression.Check crankcase ventilation.Check exhaust system for leak tightness.
Fault Impact:
The engine operates in its emergency program.
Rough engine running.
Warnings:
Warning Lights Engine warning lamp off.
