petrino_1 hat geschrieben:I have exactly the same problem but no solution
Flisi hat geschrieben:Hast du einen anderen Kupplungshebel an deiner BMW ?
Nigel hat geschrieben:Yes, I have the HP levers. I do not think it is the feeler spring (for the clutch switch) as the shifter works at lower rpm and at high rpm in gears 1-3. Only at very high rpm in 4 and 5, it does not work. I will try setting the play on the feeler again. I attached the English version by the way, so I can understand ....hahaha, stupid english boy.
N.
Saw100 hat geschrieben:Die besagte Feder, war die am orig. Hebel dran?
