Hi friends,
My Power Commander V arrived at my dealer today. I will get it fitted next week with the Autotune facilty. Will be good I hope.
Nigel.
MSHPU hat geschrieben:Are you using it to tune the ECU mapping to an aftermarket slip-on? I don't think that will be necessary with the slip on and if you have the factory shift assistant installed there isn't even a need for the Quick Shifter module. At least from what I can tell, what are the features you gain? BTW: you should be glad you can use a Power Commander, they are not street legal in Germany because they affect emissions...
shicky hat geschrieben:coole sache nigel
dann berichte mal auch gleich wie sich der einbau gestaltet
und wie der so funzt
evt noch was er bringt beim drehmoment
prüfstand wäre auch super
audacium hat geschrieben:Sorry, who is DJ?
Looking forward to hear from your results.
